No rpm signal ECU Black new sensors
So hey all ! So have 2005 Subaru non turbo with dbw
So ECU black is what we have . We used new cam and crank sensors . I made new wire harness to sensors . I have no rpm signal We ohm check sensors 1.8k ohm with harness hooked up measured at pins . Sensor terminal jumpered measure .003 taken at pins of ECU . I haven’t checked for voltage out out yet but will tonight . I can fire off coils as needed and fire injectors as needed when testing . What am I missing for no RPM reading , when scoping it is also flat line ….
