OBP linear potentiometer throttle sensor wiring
Hi i have a ecumaster black ecu and a obp linear potentiometer throttle sensor.
Im looking at the wiring example ecumaster provide and i see (tps, analog, 5v, gnd) is used to connect the throttle, but my linear potentiometer only has (signal, 5v, gnd), and a secondary signal that is the inverse of the other signal wire. (Signal 1 is low resistance, Signal 2 is high resistance on the wiper)
How should i wire it to the ecu?
[Obp linear potentiometer ](Dual Signal DBW Linear Potentiometer Dual Signal DBW Linear Potentiometer | obp Motorsport)
5V and sensor ground can be jumped at the sensor, these are shared by both pots.
signal 1 to TPS input, signal 2 to any analogue input.
I am assuming your setting up for DBW, for safety you want the check pot. If not then just use 1 of the signal wires and disregard the other one
