Paddle shifting issues with Pro 8
Hello, I’m new here and I race a pro formula Mazda with an ECU Master Pro 8, MME paddle shift system, with an AIM SW4 steering wheel logger with paddles. The issue I’m experiencing is I can shift on the stand 1-6 then 6-1 with N and R. Out on track I can go from 1 to 2 but can’t shift to 3 or higher nor downshift until the car is parked and back in N. Throttle is mechanical not DBW so I am adding a throttle blip to it for the ECU to allow it to no lift shift and downshift. Could this be to long of air line pressure problem?
Thanks in advance!
Without your project file and a log file, it would just be guesswork. We need both to help you diagnose the issue.
If you can’t upload files as a new user, you can use a file-sharing service such as WeTransfer and post the download link here.
Sorry I’m new at this. I will see what I can do! Thanks.
