Parametric output
I am setting up an electric water pump, but can someone tell me what variable #1 value represents when using coolant temp for activation. The value I have doesn’t seems to represent coolant temp to me. Thanks
see in log thease chanel, and try relace #2 “none“ to values and variable of "#1
thank you for the reply. i understand it now. variable 1 value represent Celsius Coolant temp since i pick it even thou i am using imperial.
