Please help me ! subaru ej 18/36-2-2-2
HELLO MY FRIENDS. I CANNOT START MY SUBARU VEHICLE WITH EMU BLACK. I TRIED ALL TRIGGER WHEEL GEARS (6 TOOTH - 36-2-2-2) BUT THE ENGINE DOES NOT WORK AND EVEN IF IT STARTS, IT IS VERY HARD TO START. I MADE THE SETTINGS SUITABLE FOR THE CAR PLEASE HELP ME.
subaru ej18.emub (145.6 KB)
Hi Rıdvan, if the vehicle has a WRX gear, I can send you a ready basemap, it includes the necessary timing settings. You can directly install and run it. However, if the gear is 12-1, this is a little different.
Hi Okan
I only have 6 teeth. The one with 36 teeth broke while removing them, unfortunately, I regret that my problem is not caused by memory because the valves are missing, but the map in yours can be very useful for me in the advanced stage, thank you in advance for your help.
Turkish
Elimde sadece 6 diş var. 36 diş olanı sökerken kırıldı maalesef sorunumun hatıra kaynaklı olmadığını üzülerek söylüyorum çünkü subaplar kaçırıyor ama sendeki Harita ileri safhada işime fazlasıyla yarayabilir yardımın için şimdiden teşekkür ederim.
