Problem with custom variables in tables
in some tables i use custom variables e.g. in my ignition table as Z-Axis.
I noticed that when i add new variables in the project tree sometimes the variable axis in the table changes although i didn’t touch anything in the table.
Here a befor after example…have a look on my ignition base table and knock threshold:
AudiS5_CAUA_rev73_brubbletry.emupro (32.9 KB)
AudiS5_CAUA_rev74.emupro (33.1 KB)
I didnt touch anything in the table, just added some variables in the project tree and the axis changed.
Very dangerous imo and should be fixed.
What firmware version are you using?
I cant open your files with 115.0.
IIRC this has been fixed already.
Bug confirmed.
We will fix it in the 115.2, which will be released in the next few days.
Thank you
It’s GDI FW. Just posted it here cause i thought it is a general topic.
Yes. It’s Client related and all the firmware/Client versions with 4D tables are affected.
Fixed in version 115.2-exp: New EMU PRO software version 115.2-exp
