Problems with DBW 0280750156
I installed a BOSCH DBW 0 280 750 156 with an EMU BLACK and I can’t get it to work properly.
It doesn’t open fully and keeps clicking and rattling.
I checked my wiring, everything seems fine to me.
G2-Hbridge1A to Pin4
G10-Hbridge1B to Pin1
B38-SensorGround to Pin2
B26- +5V to Pin3
B4-Analog2 to Pin5
B17-Analog3 to Pin6
I tested another one, and it does the same thing.
Have you ever encountered this problem?
Is it a compatibility issue?
Is the EMU BLACK faulty?
Thanks for your help.
I assume you’ve done the DBW calibration? Are the pos MIN/MAX voltages correct? Also check the pos input settings from the pedal? IE input & inverse. AI like chatGPT is very useful for guidance/troubleshooting, especially if you prompt it properly.
DBW side inputs
Pin Abbreviation Description
Pin 1 M- Negative Supply for Motor
Pin 2 IPM / UIP Sensor Ground (Rising) / Sensor Supply (Falling)
Pin 3 UIP / IPM Sensor Supply (Rising) / Sensor Ground (Falling)
Pin 4 M+ Positive Supply for Motor
Pin 5 IP2 Sensor 1 Signal
Pin 6 IP1 Sensor 2 Signal
I can hear mine rattling as well but the calibration tool finishes its calibration without errors. I thought it was part of the process?
