Hello everyone
i am working with ecu master black version and i am currently using the ecu at yamaha’s fazer 600 engine.
The thing is that i have also a bosch motosport dbw and i hace connected the dbw, with both a 3 pin and 4 pin pps from denso (its temporary and at the 4 pin connection the difference was the i put an analog input at second pps which had no difference and it was worse) and the problem that i am facing is that i have enabled my dbw and then when i am calibrating it finishes well and then when i am on 3% pps, the throttle plate goes to 100% immediatly. So my question is what can i do in order to fix that issue and my throttle works accordingly with my pps (pps works fine and the throttle is brand new). I will upload some screenshots such as the datasheet of the throttle in case i have messed up with wiring (like one cable or something). Thanks for your time team.
PS CALIBRATION DOESNT SOLVE THE ISSUE i have done multiple and still nothing
and the current connection that i have
DBW BOSCH 0280.750.148
PIN 1 G10
PIN2 B38
PIN 3 B26
PIN4 G2
PIN 5 B4
PIN 6 B31
You have used falling input not rising.
Swap in software anolg 1 and analog 2
i have made the switch it didnt fix the problem should i try something extra with that change in order to be applied?
Check what is your dbw target .
Makensure main position signal is rising.
Ecu assume smaller voltage on shut throttle ..
