I had a problem with the engine working sequentially. I am using a 36-2 crank trigger with a VR sensor and a single-tooth cam, also with a VR sensor. I think the sensors are functioning well because I can see the signals in the logs and on the scope, but only when I set it to wasted spark mode. When I switch to sequential mode, the signal is missing. Below, I have attached screenshots and my tune.
wasted spark works, sequential no.emub3 (57.0 KB)
