Réglage de shifter sur une boîte séquentielle avec une commande manuel
I am currently experiencing an issue with the shifter setup. The cut occurs after the gear lever action and does not work properly. I have tried adjusting different settings (cut time, sensor direction, thresholds, etc.), but I do not notice any change in the behavior.
Additionally, the launch control does not seem to work either. Despite trying several different settings, I cannot get it to activate.
Could you please advise what I should check or which settings are required to resolve these issues?
Thank you in advance for your assistance.
Please post your base map and log file to check what is a problem.
Ok, we managed to find some alternatives.
However, is it not possible to do launch control below 15% TPS?
Will be lowered for next build
