Request for clarity on help description - VSS and Gearbox
Looking for clarity of the help description in the VSS and Gearbox section of V3. The help for “Calculated from driven axle” states for Gear 1 - “The ratio multiplied by 16 of the vehicle’s speed to the engine RPM for gear 1.” can someone help me understand this please?
For context, the gearbox i’m using is a 3SGE J160, the gear ratios are the following:
First Gear: 3.874
Second Gear: 2.175
Third Gear: 1.484
Fourth Gear: 1.223
Fifth Gear: 1.000
Sixth Gear: 0.869
This is not a gear ratio this is a speed to rpm ratio. Just drive the car, and you will see it on the log.
I understand it is not a gear ratio i am asking for an explanation to the description in the help for this section. Understanding the documentation will help me set a base to work forward from correct?
Drive the car and log the gear speed to rpm ratio, enter the value you see when driving in the corresponding boxes, it’s very easy to setup like that.
Thank you will try it that way \
