Rpm limit per gear - Emu black
Hello community,
I am new here. I am Remso from East Germany and I have implemented a 4.3L engine (3UZFE of Lexus LS 430) into a Russian GAZ 66, which is a small truck (6 tons). The problem is, in 5th gear it is getting much to fast.
The fuel cut limit won`t help, due to the fact that I set it to 5000. 5000 is a feasible rpm at lower
gears but at the 5th gear it will accelerate the GAZ66-truck to a to high speed (180 km/h). Taking the wheel dimensions into consideration 3000 rpm at 5th gear gives a speed of about 110km/h.
Is there a possibilty to set a maximum rpm limit of 3000 rpm for the 5th gear in EMU Black?
Any help appreciated
Thanks and Best Regards
Remso
Use pit limiter function
Good Morning baxtercrafter,
Great, Thank you very much. That the solution.
Best regards Remso
