Hi guys, i set up the ecu for the first time and I am using the new beta software and I don’t know if its related to that but the scope does not show anything.
I have the triggers set up i think correctly based on another post on this forum (RB25det with AEM wheel), the software says that the triggers are in sync, and i have pressed the blue arrow and the loading bar appears but it doesnt “load” and it doesnt collect data. I have started for 10-15 seconds but nothing.
With a timing light i confirmed that the ignition happens at the wrong time and i would like to adjust it with the help of the scope but it just doesnt work.
Any ideas?
20250829_1930.emublog3 (595.2 KB)
mx5nismo2.emub3 (66.5 KB)
I am on the latest firmware, i downloaded everything yesterday.
I was watching the rpm and the cam signal so both triggers should work but nothing appears on the scope. My trigger angle might be wrong but honestly i have no clue what to type in so i just cpoied a setup. its a 24 -1 AEM wheel with no missing “tooth” and the cam is at TDC
20250830_1302.emublog3 (45.9 KB)
i managed to set the ignition timing, its perfectly at 10 degrees, what im actually asking. its synced but still no data on scope
okay never mind, fixed. i pressed the button at the wrong time.
How to for anyone that doesn’t have a clear understanding:
You start cranking, than the log window stops while the software is having a hiccup, then you wait until it actually goes and you see movement on the log window. then you press the blue arrow on the scope. I think for me the button sometimes turned grey even before pressing it, but that doesnt matter.
Yes, I have tried this, but it won’t record any data. I have to start the engine, wait a bit, and then press the button. I can even record it on video tomorrow if you are interested. Well, i got the scope to work and i got my ignition timing perfect but the car still doesn’t start. Could you maybe help identifying the problem? It also smells rich but i cant see anything on the lambda, and i took out a lot of fuel and experiment with other things but nothing. I can upload a start attempt with logs and scope and my emu project too.
I’ve checked it again an same.
If i press the get scope data before cranking the bar does not load and does not collect any data.
I still have to start cranking first, then wait for the jitter, and press the button.
I don’t know if it happens because i’m using a weak laptop but this is the case. Its not really annoying tho, i used to it, its just figuring it out was hours.
