Solenoid Trans Control Universal Table
We run a ton of 4L60 or 80 transmissions. They are very simple to run like the toyota trans thats already defined. For the 4L80 its just 2 shift solenoids and a PWM sol for pressure control. Theres also PWM for converter lockup but we usually do not run lockup converters in our app.
Would it be possible to setup some form of universal trans control where you would have a table to specify what solenoids are active when or for what gear? I literally thought about using the toyota control then generating a table in the project tree to follow commanded gear and activate solenoids off that.
Below is the shift chart for gear vs solenoid control for a 4l80.
We where thinking about this to. We are also interested and are willing to test it on a car in our shop.
We will add dedicated support for 4L60/80.
Multiple people asked about this already.
Universal strategy for planetary gearbox control is also an idea we had. But first we want to make a good strategy for the specific gearboxes. When we have good base for planetary control, we will try to make an universal strategy for maximum flexibility.
That sounds great, thank you.
@mkuklis_ECUMASTER
Any chance this could move through in the next month or so? We just got a batch of gen 3 di and port coyote engines that have 4l80e transmissions behind them. We have 3 of these to do.
The work on this is starting this week.
The plan is to have a beta in 2-3 weeks.
That sounds great!! Thank you
We released the new version with support for GM gearboxes.
We also added basic help for the planetary gearboxes.
Please test it thoroughly if you can.
We have no vehicle to test the strategy in practice, so everything was done on the bench.
There might be some bugs, so let us know if you have any doubts.
Any feedback will be appreciated.
Awesome, thank you. We will have things tested in the next 2 weeks.
Is there any form of manual logic or would I need to do that in the project tree manually?
What kind of logic are you referring to?
We added support for 4L60 and 4L80 with their respective shift solenoid sequence.
I was just referring to a manual mode with some type of tap input. We will use the trans as full auto maybe 60-75% of the time, the other part will be manual control.
Oh, ok.
The manual shifting is not ready yet.
We will add it for the next release.
You probably could do something with changing the threshold based on the switch input to force the gear change.
I’ve got a plan on how to switch between modes and create a manual mode. Shouldn’t be too hard honestly.
