Thank you in advance for your help.
I connected ecumaster black to my ca18det engine and started it for the first time with the base map I found.
But I don’t know how to check if my vehicle is healthy or not.
I don’t know what I should log and in what value ranges they should be.
And if my vehicle is healthy, which values should I look at to increase my fuel ignition and turbo values?
I can see the limits of my vehicle by looking at which values. Is there someone who can provide basic information and help me.
How many ca18 you prepared to learn how to tune it? Isnt it cheaper to find someone local to tu e on dyno and then if you think there is something you can adjust … to have less room.for.mistakes? Even the base map i woldnt trust to just drive without confirm its ok st least with afr sensor. You can incresse boost and fueling on road, and adjust tining on dyno, but safer for your engine is to pay to skilled worker to do for you … its slways cheaper to pay someone else if you have local or atleast at acceptable range tuner … good luck but your questions does not predict good fiture for your engine.
