I am using V 1.225 on both my computer and ECU (Classic).
When I am decelerating, the car surges strongly between 1750 to 1500 RPM. I am also having difficulty controlling the idle valve (Bosch 3 Wire without spring), and the car always overheats when idling.
In 1st, 2nd, and 3rd gear, without pushing the gas pedal, the car surges strongly between 1750 to 1500 RPM. When I press the gas pedal slightly, the surge goes back to normal.
This issue occurs regardless of whether the engine is hot or cold. There are no error messages or warning lights displayed.
I recently upgraded from Vipec V44 to Ecumaster Classic with a new harness. The radiator thermostat and water pump have been replaced, and the temperature sensor on the radiator (which controls the auxiliary electric fan for cooling) has been changed from 99 to 91 (first) and 92 to 86 (second) to kick up at lower ECT degrees.
The engine is a BMW M30B34 with a 10:1 CR, 284 Degree Schirick Cam, and a lightweight flywheel. The rest of the engine is standard.
It is a standalone ECU with a custom harness. The engine is original to the chassis of a 1986 E28M535i (Euro).
Any advice on idle and ignition would be greatly appreciated.
https://drive.google.com/file/d/1VinS85N2-ItW3EDSagALodMfhZhGCQg9/view?usp=drive_link
