Temp readings all wrong (CLT In)
Hey there, after the issues I’ve had with the triggers, I solved all of that and my K20 runs now
BUT for some reason the CLT reads absurdly high! it makes no sense.
I tried different settings but none of it seems to work
anyone ideas?
wiring seems fine but im gonna double check tomorrow.
What are ur settings and what is the characteristic curve of the sensor?
Running Bosch NTX M12-L 0280130039
and what do you mean by characteristic curve of the sensor?
I mean the curve sensor resistance vs temperature and the seetings u did in the SW.
yeah im running that Bosch NTX in the Software, but running the OEM honda one… no idea if thats correct. found that in a basemap.
aandd I guess…
It has a 0V 127 Deg to 5.0V -35 Deg curve
There are just 3 possibilities:
  • Ur sensor is not the one u assume → check PN of the sensor
  • Ur settings are wrong → share projectfile to check
  • Something is broken (wiring/sensor)
I would say that’s probably not correct.
NTD sensors all have different temp vs resistance curves.
Pull up resistor value matters a lot here too, can’t take data from a map with a 1k pull up resistor value and put a 2200 ohm pull up on a different sensor and get the same temp values
Can you find a honda temp sensor resistance vs temp table? or a sensor part number?
We can help with the right information. Sharing your map would help us help you too
Im runnig ther OEM honda sensor, wich is the:
Honda 37870-PNA-003
cant seem to find any table or curve specs anywhere.
and I have my map here, but cant upload it… what fileshare software is used here?
Can upload direct to the forum, though I think you need a certain number of posts before it will let you.
Screenshots can work too
