is there an ecu flag / variable that can be read and written for activating timing lock.
I have two use-cases for that:
I want to use this for the trailing ignition table to use it for rotary timing lock for e.g. leading -5 BTDC and trailing 15 BTDC. Without that rotary user have to alter the trailing map when using timing lock when using a ignition timing light.
Other ECUs have a flood clear mode (acc fully depressed on cranking) for rotary engines which will fall back to timing lock values during period.(13b-rew factory ECU does this aswell)
regards
