Usb port repair and now no spark
I recently sent my emu black in for repair a couple of months ago for the USB port repair. I just got it back, and now the car has no spark. I have spark when I do an output test, but none while cranking. i see the tach signal while cranking but still no spark. I’ve done a trigger test, i seen signal, but not sure what I am looking at. I’ve also checked for voltage (12 volts) at the coil and good ground. any ideas what i can be?
Check the voltage during cranking.
If the battery is flat there could be no spark.
If there is spark during outout test, the outputs are working good.
I found that the original primary trigger setting, “toothed wheel with 2 missing teeth,” no longer works for me. I only have Spark now on “multi-toothed.” Engine is question is a Toyota 3SGTE 36-2 trigger. Could someone explain to me how this can happen?
Looks like a issue with the cam sync.
Without the scope log and your settings hard to answer this question
MR2 1172026 NO START.emub (146.0 KB)
multitooth log 3 1172026.emublog (169.5 KB)
For sure the settings from your no start map is wrong.
What was your last working calibration before sending for repair ?
From the log I can see that EMU reads primary and secodnarty trigger.
Also make a scope and publish file with the calibration that worked for you before.
mr2 1182026 no start map.emub (145.6 KB)
1182026 log no start.emublog (23.9 KB)
I’ve checked shielding wire and have isolated the primary trigger wire and i am still having this noise. ive tried a different crank sensor and still the same issue. The vehicle was parked running. Not sure why I’m having this problem now.
Try to activate filter “LOW” for primarty trigger and / or 4K7 pullup or pulldown (check what will work).
i has able to get it to work 1k pulldown, medium filter, 85%. strange that this has change but am happy now that the car is back running. thank you for the help
