The update rate from the steering wheel is 50ms. 0x25 sends the steering wheel switch states as a bitfield on Byte 0. When the (currently) three switch states are sent, they work correctly if set to Can Switch 2, 3, and 4 but any one of them displays the same random on/off behavior if set to Can Switch 1.
Using 0x25 as there isn’t a lot of traffic on the bus and I’m prioritising steering wheel switches over some other data (so the horn is more likely to work when I press it etc…). But I did try it with other addresses from 0x50 to 0x600 - No change. The load on the bus as reported by the Black is ~20%.
Thanks again - I guess I’ll just have to do without Can Switch 1 (should be okay for now).
Is it possible to add the “Check engine light output” channel (not “Check engine code”) ? For send it to the CAN Switch Board V3, with a Fn. I would like to have an independent CEL (Check Engine Light) and Knock indicator light.
Hi All, the v3 guide shows trigger pull downs 4.7k as default trigger .
I’m running VR Type trigger on 1jz non . Should I keep the no pull down or pull up selected .
I thought VR Style required none. Help anyone .
Also would be nice to have 1jz non trigger in the wizard considering many of these older motors out here .
Also is there an effort to have Base start maps like other manufactures ? Dont want to just convert from v2 would rather reduce point of failure by starting with V3.
The “Check engine light output” channel, indicated in the table "Engine protection - Check engine light, is absent from the list. This output I would like on the “CAN switch on board V3”
All physical outputs on my EmuBlack are occupied by essential components.
Thank you ! Appreciate the reply . The bias of the pulldown does sharpen the trigger edge but in this case the Bias on pulldown 4.7k to ground and cause a very long start cranking duration until it’s synchronized. Is that normal ? Thank you Jadzwin
Just tried the log export - I would love to get a selection list of channels to export (that also stores the preferences - if I understand it correctly I can only choose from the up to 16 channels in a graph - or all 500+ channels?
I would also like to be able to set the scale max/min on the z-axis on the scatter plot, for short term trim it defaults to ±100, so all points are green..
But - all in all - very good work guys! Tuning with this is fun!
