Version 3.060, Release candidate
New version of EMU V3 software is available. It is just quick update, before the next build with much more improvements!
https://www.ecumaster.com/files/EMU_BLACK_V3/EMUBlackV3Setup_3_060.exe
New EDL firmware ver 1.22 available (1.21 is required for V3 firmware in version 3.051 and higher)[https://www.ecumaster.com/files/EDL/VERSION_1_22.zip ]
Change log file: changeLog.pdf
Overrun
  • Spark cut issue fixed (when overrun was blocked by blip)
Trigger system
  • 2JZ VvtI CAM decoder tooth range modified
Windows client
  • Password window appearance improved
hi @Jadzwin_ECUMASTER . i need you to look at the can stream between v2 and v3 i know they was many changes .
this is the issue >
in v2 can switch 8 = esp when u press it it stay on in log
in v3 can switch 15 = eps when press the button on it stays in some kind of a loop going on and off . when you press the switch off it stays off . in log
attached is files and logs from v2 and v3
look forward to your feed back
v2 working fine.emub (145.5 KB)
can switch 8.emublog (24.8 KB)
v2 fv 2.176 can switch 8 esp.emublog (16.3 KB)
v3 3060 can switch 15 cycle not permant.emublog3 (23.5 KB)
3.060 new.emub3 (72.4 KB)
Iam still looking forward to password protection for calibration file. :slight_smile:
Can we get MAF logging any analog input can be used we will need a 2d table to define de sensor votage vs airflow and a logging channel
In dark mode. The Arrows on the drop down list menu on the left disappears since it changes to black colour when clicked. In white mode is normal.
When you open a 3d table for the first time and you click to close the graphics 3d table on the right so keep only text menu on the left. Re-clicking it doesn’t make it appear again side by side. You can only choose either 3D or letters. V2 you could reappear both letter and 3d with the same button
Hello, i just wanted to point out an error i just found yesterday, there is problem with predefined trigger for BMW M52/54 Engines in Trigger Wizard, the firing order is incorrect - and it should be **1-5-3-6-2-4 ** instead of 1-5-3-4-2-6 as it is now its causing missfires on 4 and 6 cyl. and engine is not running smoothly.
Cheers
In this build it appears there is a bug with the ‘Save As’ function. Existing files are not listed in the folder - assume it is due to the ‘Type’ missing a seperator:
What version do you have ?
I’ve just tested and firing order seems to be right.
Also the preset name doesnt have M54 in name
v3,048 - ohh ok, maybe it’s fixed by now in newer version
Youe have selectes Save as XML file. Normally emub3 file is compressed binary file. When you save it as xml it is save as text file with xml.emub3 extension.
Appears I was getting the ‘Save as XML’ screen for both ‘Save As’ options regardless of which was selected. Uninstall and reinstall has resolved it.
Is possibile and correct this r32 bub vw decoding?
My ask make sense but my airbag control unit abbandoned me and i’m have an intermittent can bus,i’m tried a vw decoding but my opinion the motor code and vehicle code is inverted…is my problem or vw decode problem?
Base map coding
My vw coding
Here is decoding results from our AUDI 8P R32. I dont know why in base map is different coding, we will investigate it.
You should use coding from your OEM ECU (it is the best approach)
Small typo in .060
Outputs > Coolant Fan > ‘Forceed’ On Input (extra E)
Thank you!
@Jadzwin_ECUMASTER any feedback on this ?
In ur project file the CAN switch 15 isnt assigned to anything. It should do nothing. Same for 8.
Where do u think u assigned it?
in v3 can switch 15 = eps when press the button on it stays in some kind of a loop going on and off . when you press the switch off it stays off . in log .
so this below is the v3 can setup .
so in v2 esp switch was use to activate lc in the ecu can sw 8
now on v3 esp switch when i try the same thing the switch dosent latch it just gets stuck in a loop going on and off .
the change of can from v2 to v3 has some errors for my car
If I understand you correctly it is not assigned but changes the state ?
I’m not sure where is the issue
