V3 Studio 3.067
I added this to the to do list. The only problem is that lambda on idle impacts the idle RPM a lot. So for tuning Idle active state air table you need to have very good lambda in all temperature and idle RPM range.
I think its wasting of your time. Its pretty straight forward for adjusting that table and who is lazy or not able do it, will not be able to utilize some automatic function effectively anyway, no offense. I tried to rise before, that armed/inactive tables have no lookup for temperature/target rpm , they are not helping during warmup, so idle tends to dip no matter how precise active state table is(only cure is to have higher rpm target).
For the next build there will be CLT correction for armed airflow table.
