Just curious to see what set up you guys are using
You’re better off following the CAN Bus spec than using a CAN hub. Basically you need to pick your ‘first’ and ‘last’ device to be on the bus (work from the back to the front of the car/ left to right/etc - Just something logical) to be the terminals (with terminal resistors) and run a tail no longer than 30cm to each device along the way.
