What is the correct way to achieve a stored parameter in Emu PRO changed by a button for example till a specific value like 5 and then start from 0 in a loop? This value should be saved in Emu Pro and not change after power cycle.
ADU and PMU have autosaved channels but I did not find a similar thing for EMU Pro.
EMU PRO doesn’t support autosaved channels. If you have PMU or ADU you can send this value from EMU PRO by a CAN bus frame to store it and receive it back after power switch.
