I purchased EmuBlack.
It has a 4barMAP sensor, but the SupraMk4 ECU is placed inside the car.
Do you have any recommendations for a route to install a hose from the intake manifold to the inside of the car?
use ptfe plstic pipe (like in 3d printer) to route to ecu
on second end - pneumo fitting in intake manifold
This, and good high temp silicone hose. The cheap stuff collapses when it gets warm. Bulkhead fitting prevents hose from getting cut or pulled when passing through a firewall and is better then a grommet.
