Hi there all,
I need the correct & accurate voltage & temperature settings for Oem Bam engine IAT sensor.
If any one has share for knowledge thanks in advance.
Thanks allot sir ![]()
I really appreciate your support.
you can take the bosch 0280130039 with the sensor wizard.
The volt vs temp is little different now its reading accurate.
I did the calculation from the same chart, as I have the same sensor
Also have the .EMUBP if wanted
