Change root folder for PMU24 project
Ive been trying to figure this out for months now but cant find what I’m looking for.
When i first powered uo the pmu i had to set a folder to save everything into. Long storey short i mispelled that folder so i manually created another folder and saved into there. The problem is the software always defaults back to my original mispelled folder and i cant figure out how to change it.
Top menu / Device / Set device name
Thanks, but unfortunately it didnt work. Even if i delete the original folder. When i goes to save it recreates the original folder instead of saving to the one i want
There is a file named devices.xml in your Documents/PMU/ folder.
You can manually edit this file.
You can even delete it, and the next time you connect, you’ll be prompted to enter the folder name again.
Perfect ill give this a try. Its not a deal breaker its just a little niggle
That did the job, thank you
