DBW Idle Target Min possible increase?
Is there any way to increase this beyond 10%? We run into larger CI v8s that will require around 17-20% for idle. Right now I’m just using an offset to help but the 10% min causes an idle dip at times.
Sure, we can change that.
I am thinking that 35% as a maximum value should cover everything, right?
Edit:
I see I misunderstood the question.
Minimum position has a maximum value of 10% and you want it higher, so the throttle can’t close as much during idle.
We will remove this limitation completely.
Unless I’m looking at it wrong? LOL I was using an adder and the actual pedal demand table to try and keep a min blade.
Yes, I see that too on LSx engines. I’ve seen idle as high as 21% via HPTuners.
