Dq250 dsg cxx vr6turbo
Hi Alexander sorry for late reply, i did the tune with StageX from magic motorsport! With my tune i can reach 18,4 bar clutch pressure.
Thanks, StageX looks really fancy! What hardware did you use to upload your tune to DSG?
I’m using pcm flash for my dsg reading and writing and chiptuner pro for tuning definitions. I have learned a decent amount about tuning these in the past 2 years.
Did you already have a solution?
I have a tt 8j 3.2 BUB with HXX ​​DQ250 (Passat)
The error code 01314 keeps appearing for me.
I can provoke the error by quickly stepping on the gas pedal and going past the kickdown.
Hi Alex, can you share your contact info? Email / whatsapp?
I will need your help to tune a DSG FXX file.
Share please map and log when it appears
Have HXX and drive without error. So the solution it’s maybe easy fix
Found the Solution.
DBW charakteristik at 90-100% tps slowly increase in lower Rpm.
Otherwise the ABS detecting an error.
Do I simply need to make sure the two numbers are equal? I got a TVS Stage2+ dsg tune with 500nm max torque. Does it mean I simply need to set VAG MDI torque to 500nm and that’s it?
Hello All,
today i changed from V2 to V3 Firmware 3.044c. The fault from the power steering is solved. So now i have to do new tune because with V3 my car runs extremly rich and idle is completly diffrent strategy. I will keep you updated if the fault comes back (fingers crossed)
