Dsg dq250 in Citroen c2 issues with gearbox map
Have a 1.8t / dq250 in a Citroen c2
Runs and drives but having massive issues with Dsg.
Have tried 2 gearboxes and 3 mechs all with the same issue so must be to do with emu setup
Looking for someone experienced with v3 and Dsg on a standalone car that can try and resolve the issue
Anyone have dq250 working properly on v3 with this kind of setup?
how good it drives seems to depend on key cycles. As in if you power the car off and restart it it can be better or worse.
Ben
MAP and log? Which version are you running?
Thanks, I’ll get them logged later and uploaded tomorrow
c2dsg.emub3 (68.2 KB)
good dsg cycle.emublog3 (1.2 MB)
bad dsg behaviour.emublog3 (465.8 KB)
Look at the AUDIA3_R32_BUB_FW_3_057_V1.emub3 base map included with the V3.
It is abase map for AUDI and DQ250. The gearbox works well.
Also make sure there is no can ID clash between DSG CAN messages and your car CAN ids.
Also check with the VCDS if the gearbox reads properly the torque and if there are any errors
Please update us if you see any errors in VCDS.
Definitely no errors on canbus
I will update with any errors in vcds etc later or tomorrow
Will try data from the base map
Ben
Base map copied over and it drives better but doesn’t resolve the issues
vcds is reading torque fine
fault codes attached
what issues do you have ?
What exactly do you mean by ‘‘but doesn’t resolve the issues’’ ?
And by the way, if you have a full backup of the TCU your running now, I may support with a proper TCU tune. You will need to flash it with FLEX, Autotuner or something similar…
On one key cycle of the ignition it runs fine
On what I would call a bad key cycle it delays when going into gear, won’t pull away once in gear or stalls
At this point the car has to be turned off and restarted
Sometimes this will happen for 1 key cycle sometimes it will happen for 10 or more
The log files I uploaded show two logs one for bad cycle one for good
Have tried with standard tcu file and a mapped tcu file. This doesn’t make any difference to The issue
Did you check with VCDS when the dsg works wrong ?
This is very weird behaviour!!! Are you running a FXX mech?
On btoh logs I can see dsg fault flag set to 1.
Do youbahve any usb2can device to analyze can bus traffic ?
I can check with vcds no problem
Can you guide me what to check for? Thanks
Will check the mech model and come back to
You
Yes I have usb2can. Do you want me to log and upload?
Follow the steps to record logs for properly and not properly running DSG.
  1. Start Light cllient
  2. Press Clear button
  3. Make a short drive
  4. Save file to disk.
Also when the DSG is not working please check wiht the VCDS for errors. The errors you send before shouldnt influence the gearbox behaviour.
