🐞 eDash Beta – Bug Reporting & Status
Still haven’t been able to connect my Samsung A26 to the EDL1 - it doesn’t even show up when searching Bluetooth on the Samsung settings, the EMU dash 3 app, the Edash app, or Real Dash
I have an old Samsung tablet (Android 7) that used to connect fine, but now it connects on the EMU dash 3 app and the Real Dash app, but doesn’t show any data, not sure if something has changed compatibility with the 1.26 version fw on the device
Ive seen mention of “old EDL1” having less Bluetooth compatibility, is there any specific info on this somewhere, how to tell what EDL1 I have and what the issues are?
I do have a problem with proper TPS display.
It shows only up to 50% where on EMU app it’s displayed properly 100%
Samsunng s23
Android 16
0.0.43(24)
Emu Classic
BT Module
Quick question. Can the app use speed sourced from the phone/tablet GPS?
or does one have to have a speed input wired directly to the ecu? My old car has a cable and I just ordered my emu black and datalogger BT device. Looking forward to trying the app in-car!
Already requested this as a channel for the app. Currently there is no channel for phone(gps) based speed.
A new eDash beta version 0.0.48 is now available :rocket:
Please update the app and let us know how it works for you — this release includes a lot of improvements and bug fixes based directly on your feedback.
Some of the changes included in this version:
  • Fixed Android 11 permission issue
    @DIMITRIS_ECUMASTER @noobtuner
  • Added SPP support for Android devices
    Devices such as BT to CAN, BT Module, and older EDL-1 units that were previously not detected by the app should now be visible and available for connection.
    @Joehousie @westerchester.2jz @Frenny @xsd @Oliver - please test :slight_smile:
  • Added new sizes for RPM Bar, Shift Light, Gauge, Text Value, and Rotary Switch widgets
    @chrisr @noobtuner
  • Added “Show Border” and “Transparent Background” options for all widget types
    @JWR.Jeremy
  • Added alarm support for the Text Value widget
    @Anarcione
:clipboard: Full changelog
We also improved overall Bluetooth handling and stability in many areas, so even if your issue is not listed directly, please give the new version a try.
Happy testing! :fire:
More improvements are already in progress, and as always — all feedback about this version is highly appreciated.
Best,
Joanna
Device model : Samsung S25 Ultra
Android version : 16
App version / build number : v 0.0.48
ECU model : EMU Black V3
Connection type : EDL-1
Rotary button goes to 15 didn’t find a option to limit it to 9 to use it correctly on the emu black v3 software most tables limited to 9 either extend the ecu software or make a possible to limit it . Maybe add a way to lable single step like setting 2 is 2000 rpm so I can label it to 2000
Thank you
Lenovo Tablet TB7306F
ANDROID 11
EMU BLACK FW 3.065(b)
CAN BT Module
eDash Pro 48
Thanks for the improvements, amazing.
This is the device for which I was most excited about the app, so I’m really happy its communicating now.
I really like the Available Devices filter to only display ECU MASTER devices. Great idea.
Also thanks for improving the widget’s and increasing the number of custom sizes.
I’ve had a few crashes at different moments. Sometimes in response to a button and sometimes random. I’ll pay more attention to what actions might be consistently inducing the crash and update soon.
Is there a way I can capture meaningful crash data for you?
TPS is still scaling to 50% at WOT while client is responding normally.
Request:
Is it easy to make more colour options with a selectable colour palet for boarders and text? This would mean the possibility to match OE interior dash lighting and console switch backlighting for example.
Thanks again, loving it.
Mal.
Thanks for the Update.
Have done the upgrade and can now connect over bluetooth, but it does not show any data.
Reflashing Firmware does not change anything
I have the same issues with my classic 1.227 and 2 smartphone android 16
After updating EDL1 firmware to version 1.27, I have the same result:
App connected
No data reception
Bluetooth module error in the file EDL-info.txt
First of all thanks for the update.I really appreciate the effort you guys put in the edash.
One upgrade that stands out for me is the ability to reconnect the app to bluetooth without closing and reopening the app. I did mentioned it and it resolved, thanks.
However, I was only able to install the updated 0.48 version on my Samsung S20 Ultra (Android 13)
The app would not install on my android radio. After trying for hours I got nowhere. I also tried the apk and wasn’t successful.
Android version: 13.0
Memory: 4.0G
Storage: 64G
System platform: Haudio
Can info: LuZheng/HaoZheng->Toyota/Lexusis->LC
CAN version number: 5.0.1.20250723
Build number: RK_ 2025.08.14.19_3_4424
B Mcu version: RK001_25.05.13_479
Monitor info; 1280*720_WD090HBM3OAC-S2-10
TP info; GT9xx_1080x600
Edash 0.48
The apk version stated “There was a problem parsing the package”
Is it possible to increase the maximum size of the widgets?
This would be helpful when using a smartphone, as it would allow just two or three key values to be read clearly in a larger format during driving.
  • Samsung s24
  • Android 16
  • App version 0.0.48
  • EMU Classic 1.227
  • BT Module
  • Very slow refresh rate , no energy saving mode etc. BT Module visible ony in spp , no problem with connection.
Screen_Recording_20260602_205306_eDash
Hi, did You solve this problem? I have the same issue as You :frowning:
Onn tablet pro - Android 11
App: 0.0.48
Emu black, v3 3.064
EDL-1 1.27
Same as other folks, i can now connect, but no data, i tried removing my can setup.
Removing can bus stream for haltech v1, no data on edash
Changing Bus speed from 1mbpps to 500kbps, can bus indicator on the laptop shows Can bus error, switching back to 1mbpps shows a green can bus icon
Send data to btcan module enabled/disabled
Send emu stream over canbus enabled/disabled
No changes on eDash getting data.
I’ve still got logging issues and not had any reply on here. Upgraded the firmware to V27 and worked for around a minute and now I have a flashing red light and not logging any data onto SD card. App works fine.
Might not be the same scenario but i did get a lot of random red light failures when my SD card started going bad. Try a new/proven one just in case
After research the problem is old spp BT Module on some new android devices , to solve this change BT Module to ble device. Refresh rate is a way better :wink:
Screen_Recording_20260605_155255_eDash
Device model : Samsung Galaxy A17 and Oppo
ECU model : EMU Classic v 1.227
Connection type : EDL-1 version 1.27
The application installed on both smartphones recognizes the EDL1 with spp protocol but no data is received. Data is received and saved to the SD card correctly.
In the "EDL-info" file it's written "Bluetooh module error". If I load version 1.26 into EDL1, the "EDL-info" file is it correct but the problem with data reception persists
has anyone made a comparison between the old emudash and the new edash app ? Is it my feeling that old emudash is a little more responsive displaying the values e.x. RPM ?
:rocket: New EDL firmware is now available!
EDL Firmware 1.28 - eDash Open Beta - Ecumaster Community
We’ve released a new firmware version for EDL that resolves an issue affecting some older EDL-1 modules, where the connection was established but no data was received by eDash.
If you have experienced this problem, please update to the latest firmware and let us know if it fixes it for you.
Special request to:
@xsd
@diegoevo
@Tyniek
Could you please install the new firmware and confirm whether data is now being received correctly?
Thanks for your help and feedback!
