lets say you dont want someone to find the power map by simply pushing some buttons. ![]()
You can create the function that the button must be pressed given time until change the state
The function can look like this:
You need to keep the Switch #1 at least 5 seconds to change its state.
V3 firmware will be work with the “CAN switch board V3” ?
With more possibility to assign the 4 low side outputs ?
The Bluetooth CAN BUS module will be work ?
Excellent… will the information be on here, or FB etc?
Cheers.
Steve
Waiting , soon have to start engine ![]()
Hi there, will you be updating your app for android? would be interesting and good to have switches on the fly, for example, boost, maps, flat shift on/ off.
Thanks,
would be great to have a working android app! i cant find them like nowhere. emudash v2 v3 sometimes work, sometimes wont
Any updates on this?
Can you add options like check engine light, knock light, parametric light… in EMUDASH android app ?
This will allow to save on the physical pinout on EMU and the CAN switch board.
We plan to develop a new Bluetooth module and a new app, but that will start after we finish the big projects.
Great. Try to make it like with the Swedish controller where you can display any parameter, even one created by yourself, so you can switch maps or control other settings like LC or ALS, it’s just a suggestion. Thank you.
sorry for being pain in the ass but can you make an example for a map switch? so i set the operator fuction like in your picture for example. do i need to set a output or action? as the dropdown menu only shows output only, rev limiter, ignition correction and set check engine. but i let switch 1 work as a map switch. so i need to use the fuction output stuff? or can i just setup the true value for the 10seconds delay? and after this 10sec the map will switch?
Any news ?
Cheers
Steve
I’ve literally got my car sat on the dyno waiting for V3 software.
how to sign up for the list, I want to try out the new software
The open beta software will be available on this page?
Should be this week… (based on info from last week)
So we have 3 days of waiting ![]()
Please could we have an update to when V3 beta software will be available. Thanks
Should be last week regarding the info here in history.
