Gm LT1 optispark trigger setup
Hi. I have Emu black v3 soft and Gm Lt1 v8 stock engine with optispark ignition. It has 360 slots for crank and 8 slots for cam (4 same length 2degrees and 4 different lengths). For crank nissan trigger and for cam i have used nissan trigger but i have no spark. Output test works.I don’t understand what I should actually select so that the emu reads a specific camshaft range for synchronization. In the link i have some files for my emu setup and picoscope file and pdf for optispark trigger pattern measured with in-cylinder pressure from cyl 1. Or do i need to make a new trigger disk for my optispark.
