New software 3.026 is available!
Lots of changes and improvements :slight_smile:
Link to the software:
[https://www.ecumaster.com/files/EMU_BLACK_V3/EMUBlackV3Setup_3_026b.exe ]
EDL firmware
Change log:
  1. Triggers added: 18_2_18_2 (wrangler, hemi, Nissan, qr25det), new cam decoders for Jeep Wrangler and Hemi.
  2. User Functions: Hysteresis operator for functions added
  3. User Functions: Output “None” in functions outputs renamed to “Virtual”
  4. MUX switch grayed options bug fixed
  5. TPS interval rate increased to 100ms
  6. Append EDL1 files fixed (bg3)
  7. Ford Focus RS (Normal, Comfort, Sport) modes received by CAN (Latching switch 4)
  8. 4 CAN analog inputs (CAN Analog 9 to 12) added
  9. 4 CAN switches (CAN SW 17 to 20) added
  10. Idle Airflow override
  11. DBW characteristic blend was 100% when the characteristic switch was not assigned
  12. When Idle spark / fuel cut was selected and the idle controller was inactive the cut % was equal to Max cut %. Now the cut percent is 0% in such a situation.
  13. New channels for custom axes added (PWM, Fuel and IGn corre tables): ANALOG CAN 9-12, Boost, Injectors DC
  14. Boost controller: When Boost is under margin the user can define the solenoid DC (Max DC or DC from Duty cycle feedback table).
  15. Boost controller: Solenoid can be disabled under defined MAP pressure
  16. Boost controller: DC on the log is always clamped to the MIN/MAX DC. When the solenoid is disabled under MAP conditions, the DC is 0 (no power to output)
  17. VVTI: CAM1 and CAM2 tables now have independent Y axes
  18. VVTI: Bug with reading tables when ALPHA-N fuel strategy was selected fixed
  19. Dwell over 12.5ms bug fixed
  20. DBW characteristic table Y axis can be set to MAP
  21. CAN Rotary switches added to User defined CAN
  22. Left double-click on the graph log channels enter their configuration
  23. Autotune - higher threshold for TPS rate
  24. Autoutne - new log channel Autotune rejection reason to check what samples from log were rejected and why
  25. CSB V1 support bug fixed
  26. Restore default parameters for variable windows, and refresh properly 3D tables with custom axes.
There is a bug for custom axes, the maximum “injectors DC” is limited to 50%.
And “Undo” doesn’t work to return on previous custom axe.
Is it possible to add channels “boost target” and “injectors PW” or “VE” ?
Yes it is possible.
Undon sholkd work. Probably the table doesnt refresh on display.
Boost control in 3.026 is much more tuneable:-)!Thank you!
