New software 3.032 is available! (update 3.032b)
it shows two values min and max. they are very near to each other and the numbers overlap
That is a very good change, I feel a lot of people will be getting confused with the way it works!
so i am 3.032 at the moment. where to find the settings for the turbo speed divider etc? or is it just vss divider? and do i log just the vss input in hz? a bit of help would be cool. thx
Sensors / Other
Probably you have version 3.031 in your ECU so this option wasn’t available :slight_smile:
For FF temperature you need to go into Temperature sensor / Standard sensors and then select flex fuel for Fuel temperature sensor.
me stupid. you were faster than me. i was on 3.032. really dont know. maybe because i set it to take data from emu and not from client at the startup.
it doesnt matter. the options always match the firmware in device when connected.
i let you know tomorrow if i got a turbo speed signal :slight_smile:
New Windows client released. Please read the first post.
Thank you.
Dear Jadzwin, can you make the EPC light blink when there is knocking?
Is there any reason the short term trim now reads some number in the 90%'s where in the previous version(s) it would be +/- from zero?
My idle is tuned to the correct AFR without short term trim, when enabled it flicks around between 94-97% on the display?
I was about to post the same question. my Short term trim reads like V2 used to as a factor of 100. so when pulling 5% fuel it shows 95% etc.
It is a bug in log channel definition. The fix will be soon. Thanks for reporting.
Good news is the correction of the fuel is proper.
All AFRs follow target within .05 but the Autotune is asking for a very large correction.
thank you guys so much. big love to the ecumaster team
New version 3.032c is ready to download. It fixes this issue as well as the autotune.
Is there / was there the bug with Lambda 2 CAN? Fixed with this FW? My Lambda 2 CAN still in your lab, maybe it’s time to ask to send it back to me :slight_smile:
There wasnt any issue with lambda to CAN @ 0x664
Not a huge issue but on my laptop I can’t see the top of the config table and are unable to move the window down. 3.032c
change resolution of the screen temporary do all setting you need and go back to previous … that’s work around it
