Are alll tables from all tabs closed ?
Is there any specific table that need to be on the desktop before closing to cause the crash ?
Is this happening when you are connected to ECU or online ?
I was able to reproduce the 2nd issue, but I cannot reproduce the 1st
I am working on triiger settings and I just want to be sure that my understanding is correct.
Currently Iam running 36-1 primary trigger welded on main pulley (not ctock). Secondary CAM trigger is currently mounted on 3D printed holder just for testing and its “looking” to the camshaft hole (“one tooth”).
I would like to find the correct position and timing.
How the position of cam sensor should be set? Is it correct to to it like in the picture. Overlaped with primary 1st trigger tooth?
Before I make final version of the sensor holdet, I would like to adk for some hints or advices.
Are there some limitations how EMU understands the position?
It is good as it is For missing tooth application just make sure the used signal edge doesnt allign with the first tooth after gap. On your emu scope the falling edge is several tooth after the gap what is ok.
I’ve copied over everything from V2 but V3 is not firing the injectorsScope is seeing Cyl#s and showing ignition dwell and showing RPM while cranking. The start switch is through the ECU but not showing in cranking mode while cranking. Any help would be appreciated. I tried test output on the injectors and they don’t pulse.
