The fact that when I do an output test on the injectors they don’t fire confuses me
In most harnesses the injectors are supplied by the fuelpump relais and this is off in not running state. Are u sure power is present?
It runs in V2. So should be no issue there
i really cant imagine how is running without cam sensor how recognise a phase… hmmm unless is always stopped on the same phase and started …
It is alive, now I can’t get it to rev over 1600. Just shuts off
Show your log with shut off.
Shut of at 1600.emublog3 (31.3 KB)
can you publish the V3 project that was used to make a log and V2 base map what worked for you ?
V3 Matt 11.18 Hall effect trigger.emub3 (63.3 KB)
Matt 11.13.24 firmware update.emub (145.5 KB)
Changed it back to VR sensor and now will rev
Okay not sure what’s going on I changed the pickup to VR and saved it then it would start and rev great started tuning and saving then it quit starting and Scope didn’t look good changed it back to Hall/Optical and then starts and back to not reving over 1600 and only if slowly accelerate to that.
Shut down program and car. Reloaded V3 with VR sensor and installed to computer and now it revs and am tuning.
Thanks to all that tried to help.
hi, dbw blip by can doesnt work like it should
20241121_1203 blip.emublog3 (722.0 KB)
it whas working on v2 perfeclty
do you have project? we use it, deruktratt use it and it works perfect. It is very simple code.
Which firmware version do you use ? I can see that CAN control is disbaled by overrun.
Are you sure the CAN control message is send faster than 20ms ? The time out for DBW control is 20ms
Hi, last open software 3.040
Did the timeout change from v2 to v3 ?
Best regards Hermans Pieter
Technical director KCPerformance
Yes it was 40ms in V2, but for safety reason I decided to change is to 20ms. So if something fails with CAN, the ECU control will be restored after 20ms.
And also 100Hz give better control than 50Hz.
just found out i cant adjust this in HTG.
so need to find a way around gone check frequentie with canlight client to see
I add timeout parameter for next build
Its only 20hz and i am trying to get adam to change it to 100hz but no idea of he Gone do it.
Thanks !
