Did you try with another phone / tablet ?
In about week. We made a lot of changes and add Nitrous support what we need to test on the engine
Yes, i use car radio on android, the same problem dont connect.
Hello, thank you for quick answer.
1 - Iam using EDL-1 with last recome ded FW.
As Android app I use version 3.0.22.R
App is no longer in GooglePlay so I have what I have ![]()
(Is there any info when new app will be released or some features we can look forward?)
3 - Thats fixed valvetrain with only one CAM. Iam also curious why the the mark appears in totaly diferent position than it should based o manual descrtion.
(should I test diferent settings, can you recomemt something?)
For my point of view, in my case âone toothâ is the case Ishoud use.
4 - Is there manual how measurement channels are calculated or its secret ;)?
I really aprreciate when you shared bitfield meaning in past ! Thats also very helpful!
- Ok we wil check it again. We are working on totally new application for Android and IOS
- The 2nd sope is the same as your real oscilloscope shoot. The selected CAM pattern doesnât influence the mark on the scope. So it is very mysterious. Maybe it was a noise ? Could you check it again on working engine ? In your case both cam decoders will work
- Iâm not sure if I understand your question.
In the help for function (if you select Fn1) there is information about all enumerations and bitfields (what is useful for functions)
In User defined CAN there is information about available input channels:
Or you want to know something else
someone spot the problem? its happening only is pps is more than 95%
DBW hw state : error no signal ( it means dbw position or no signal with secondary micochip?)
Dyno_v1 515hp.emub3 (70.0 KB)
dbw error 14,38.emublog3 (2.1 MB)
i think your pps check signal is set wrong you have 2v on on check signal when full pedal on your table is set 4.5 i think
thanks i was looking in wrong place its problem with pps.
great to hear you are working on a new android and ios version of emu dash.
Curious, I canât find this. I have dual O2 sensors and want to control one bank with on and the opposite bank with the other. Is there a way to do this?
Mine isnât working, either. IOS
From were Acc. enrich. async PW got those numbers?
look at maps and tps rate
log is to big to upload
lst1.emub3 (70.3 KB)
Read the help for asynch table. 0 doesnt mean zero enrich.
Sensors and inputs â Built-in switches ?
Shouldnât you be using an analog input instead of a switch?
In regard of staged injection in a 4 cyl engine.
Can I connect secondary injector 1&2 to one output and 3&4 to the other output? Or do I need to follow a specific order here?
Thanks in advance : )
No , all analogs are in use . On V2 works fine .
