New software 3.047 available!
You should use V3 as it is much better firmware
The differential oild pressure resolution is 0.125 Bar. The issue you have is just rounding.
The pressure is 0.75 but there is only 1 decimal point so the result is rounded to 0.8
Isn’t that the TDC of the compression stroke?
I want the injection to end at the intake stroke (just before the valve opens).
In this case, I would like to know whether it is 360+40 or 360-40.
This a Diesel schema but 360 and 720 is the same,changeover the injection angle stroke
Depending on your cam profile when the valve open but you research the start point
Start injection exact angle and end for ammount of benzin
End of injection exact and start for ammount of benzin
Much benzin much time
I prefer to finish the injection at 300/280 degrees but I have large injectors
injecting at 360 or + in valve overlap I don’t know how convenient it is
Blockquote
The way this chart is expressed is wonderful.
If this timing display and the Black setting are the same, I understand it very well.
This is a little off-topic from the purpose of this thread, but I am also wondering whether it is better to set the end of injection to after the valve opens.
first open the intake valve / 360 / close the exhaust valve…I try to not inject with the exhaust valve open
my problem was solved, checking cables and everywhere…the problem was mechanical, the oil return spring…thanks for the time spent for me
Hi Guys any info on this
Do you have trigger setup for Honda K24 available
Hi Jadzwin,
I’ve changed this setting and now car hasn’t stalled since. Not sure why this was needed as I’ve not any any issues with stalling pre 3.044
Facing an issue with what seems to be incorrect knock reporting? Even though the sensor values are well below the engine noise limit, I am still having engine lights thrown and knock events recorded. I have attached a screenshot and the logs.
This seems to be happening outside of the set knock parameters such as minimum RPM and TPS, as well as the details previously mentioned.
Google drive link as the file is too large
Latest Map.emub3 (70.2 KB)
Also just other positive feedback external to this issue, we had a failing fuel pressure regulator, and thanks to the V3’s ability to reference the fuel pressure sensor we didn’t even know until it started showing errors for fuel pressure. AFRs stayed bang on, even when we lost 1 bar of effective pressure. Great stuff there!
It is already known issue with the Knock status always active (after any knock event).
Will be fixed for 3.048 (next build).
What is the reason not to use just AC clutch strategy ?
Hi Jadzwin, I selected an H-bridge (2A), and the air conditioner is working now i ended up just using ac contol . But I also noticed that my CAN switches are not working, but were working in v2. In v2, if I pressed the traction control button, it was linked to CAN switch 8 in v3, it is not doing anything. The brake switch does work on CAN, but the clutch switch is also not registering.
what CAN stream ? For most can stream the can switches from 20 downwards are used.
Hi Jadzwin,
Sorry, I’m not exactly sure how to check that. My Audi is selected under the CAN setup, and the dash is working perfectly. But the traction control CAN switch (which was set to CAN switch 8) isn’t working.
When I press the button in V3, nothing shows up in the logs—there’s no response at all.
Hello Jakub,
When user maximize any window and want to return it to its original size, it doesn’t work, it stays on the entire screen, you have to drag it by the corner to reduce it to the desired size.
It would be very grateful if the user could import maps including X and Y axes from another project file, so that you don’t have to save the maps separately or open another project in parallel and copy it, it takes a lot of time and a lot of files that are difficult to navigate. Importing a saved map also doesn’t work correctly, because the X and Y axes are not imported, which is why you have to open the project in parallel and check the axes for compliance. Is there a possibility in the close future that the user can import separate maps including X and Y axes from a successful project to start working on a new project?
What 4cyl engine is this?
@Jadzwin_ECUMASTER i looked at the wrong place ,ignore the above. The can switch8 moved to can switch 15 in V3 . The only other issue i have if i start the car the rpm jumps to 2300Rpm how do i fix this or ajust this
Hi guys any advice on this
