R32 Golf Cam Settings
Hy,
Car: R32 BUB
I have problems with my vvt. Adjusted as follows: unplugged the plug and set the offset until I was at 0 degrees in the log. Plugged it back in and took it for a test drive. Exhaust shaft barely moves. The inlet shaft, on the other hand, works in exactly the opposite direction. Does anyone recognize my problem? Both ran in V2.
What do your Cam Angle Tables look like?
Den Auslass würd I beim turbo ehrlich gesagt ab dem Zeitpunkt wo BOOST anliegt auf spät stellen. Und Einlass kannst denk ich noch bissl länger früh stehen lassen
I didn’t use the outlet on v2. The values ​​are currently only used as a test.
My tables are configured different, but your settings are all basically the same as mine with the exceptions of the offset values. The PID, Digital configuration and Trigger settings are all the same. Not sure why you are experiencing issues. perhaps take it for a good drive and log it, then add the logs and config file here so it can be reviewed.
If your cams are moving in the wrong direction, do you have the outputs switched maybe?
Good Question.
I will try to Change Tomorrow.
I run BUB with pnp BFH adapter.
Greetings,
Issues trying to start my R32t with V3, I created the new map very similar with what I have on V2 but no start. Not sure where is my issue. I tried to upload the V3 map in here for your review but I does not allow me to. Will appreciate if anybody wants to share a base map.
My ignition parameters are set up as follow,
Primary trigger: Toothed wheel with 2 missing theeth, Falling
Secondary trigger: N+, risisng
CAM 2: Primary teeth window, rising
Firing order: 1,5,3,6,2,4 w. invert phase
Ignition output matching firing order
I run BUB with pnp adapter, any advice will be appreciate.
here you are settings for BUB
Thanks for the quick reply, are this settings the same for BFH R32 mk4 engines?
The reason I ask you is because I just found out that my engine code is BFH, I thought it was BUB. Thanks for your help.
i have no idea if they are the same
yes both the same. mk5 just needs a pwm signal for the coolant fan
Hi Axel, does your R32 work now with the above settings?
She started with the above settings, just working on the DBW calibration. Found out that it was not well calibrated. I’m pretty sure it will work fine after I deal with the DBW situation.
Gents,
After trying for a few hour I’m not able to get her running, not sure where is the issue. DBW is calibrated as it should, trigger and cams setting are setup just as above but honestly don’t know what is the issue. Kindly asking for assistance at this point. See below the map,
First map V3 2025.emub3 (62.2 KB)
Will really appreciate your help,
your cranking fuel versus what on help file
will never start this is not like V2 in ms
Send a log form cranking as well as scope file.
