Software opinions
please pubslish scope log and calibration
DBW settings - disable when no RPM working now differently? In my case TB is silent just until you press pedal
Yes. It is disabled only when the pedal is not pressed. That behavior allows you to test and use DBW without the need to start the engine or change parameters.
Have a good day
Jakub
Thanks Jakub…Im also missing deadband settings in DBW prevent 0,1% oscilation
hi all. Tell me when will the nitrous function be added as i use it to control WMI injection
many thanks
Hi, I have a question about the RTA Algorithms.
What’s the difference between 0, 1, 2 and 3?
Thanks!
For next update the EWG support will be included and bugs fixed + some minor improvements. The Nitrous function will be available after that (I think about 2 weeks from now in version 3.031)
It is for real time tuning on the dyno it calculates the VE table correction in different ways.
I’ve used it before but never tested another algorithm.
Is there an overview somewhere that shows the different ‘approaches’ to the RTA?
No there isn’t. I will analyze the code and I let you know.
Jadzwin_ECUMASTER
Dq500 does not shift down on V3 when you want to accelerate in traffic. Everything was fine at V2. I pressed the accelerator pedal and depending on the pressure, it shifted down into 1-2-3 gears. On V3 it shifted down to 1 when it needs 2, at most to 2 when it needs 3. And it tries to pull in that gear until the required boost appears.
you need to set the cranking rpm higher!
Have you any advice for me please? How to prevent 0,1% TB oscilation ?
0,1% is a very low voltage difference and it can be caused by the noise (it is 0.005V)
You can play with the friction factor and / or increase integral gain.
But it can be electric noise. You can just ignore it as well.
Nothing much but noticed a typo under fuel composition. I think it should be a “,” instead of “m”
Thanks! Fixed :slight_smile:
Would it be possible to remove the restriction of Max 60% in Ethanol corrections so I can use this table when blending Methanol with Flex fuel as it requires a lot more fuel to be added than Ethanol.
Please use the Custom correction instead and put Ethanol content on the axis
And 0 out the Ethanol correction table?
Depends on you. In Custom correction table you can add up to 155% fuel. If it is enough, set the ethanol correction to 0%
