Thursday,18,July,2024,20:47:26:49237
VCDS Version: Release 24.5.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP80.clb
Control Module Part Number: 6Q0 907 379 AT HW: 6Q0 907 379 AT
Component and/or Version: ESP 8.0 front H03 0003
Software Coding: 0002317
Work Shop Code: WSC 31414 000 00000
VCID: 0F7A48D2FB416922DE9-50D0
2 Faults Found:
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 160
Mileage: 148528 km
Time Indication: 0
01314 - Engine Control Module
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 200
Mileage: 148528 km
Time Indication: 0
this is in the abs system
I will find out the soulution.
Is your ABS MK_60 or MK_70 ?
Please try the following firmware.
Make sure you will update the firmware with this file.
And make sure to use the coding I have sent before.
https://www.ecumaster.com/files/EMU_BLACK_V3/emuBlack_3_031_ABS_VW.zip
Napkin
449
i found a typo in the 31 version. donno if its already been posted.
go to the user names and clean those corrupted characters.
hi so i still have the same faults in the abs system with the new file and the recommended settings
m4rt1n
453
Try to change dsg type to custom coding and set there can version engine version and gearbox code
i have tried this many times still don’t work. its almost like the can message is not correct for the abs pump in this car
m4rt1n
455
In can settings AND dsg settings?
Can you provide a can log with emu and these settings?
If you enable DSG, only DSG custom settings are used.
It is strange as the error in gearbox states there is coding issue.
What does happen when you reset both errors ?
Are they appear immediately ?
yes in the CAN setting and dsg . I can take a log with the current setting if needed
so clear it with vcds and the abs lamp and traction works after less then 30secends. faults come back and abs and traction lamp comes on .
new can logs with stock ecu no warning lamps and eum black with abs warning lamps
here is the link to the new can logs with the current can settings as sent
I’ve added additional tool in V3 software, that decode trace file and can apply proper coding.
hi i did not find the tool that can decode it . is it still to be updated in the v3.032 ?
still same behavior from the abs with the same faults
here is new trace log
