Use functions like this
that was exactly what i needed to see, thank you. also i dont see the vw 3.2l vr6 cam trigger in the drop down, its a 4 tooth trigger wheel not sure if that pattern is the same as the 1.8t or not. what secondary trigger should i use?
Hello! found a small graphical bug in Coils - Ignition Outputs version 3.025
You need to enter menu / User names/Outptus and clear garbage that is there.
It happens when you upgrade from V2 to V3, will be fixed in next release.
You can also use just user switch.
Assign your analog input to 1 from 8 user switches and then you can assign it to Brake pedal switch.
Hi. With the new “functions” which appear to be similar to the PMU, is it possible to get the Hysteresis option? or is this a limitation with the firmware/processing?
Is it possible to add a simple switch function for the Boost targets (so i can use a Switch to go High and Low Boost?
Just assign switch to rotary. Then the rotary will have 2 positions, 0 and 1.
In rotary switch blend enter 0 in column 0 and 100 in column 1 to 9
You really gotta put that in the help text somewhere. I think this problem came up quite often until now. ![]()
Yes
it will be in boost section.
Aaaaaahhh maan and i thought i’d get to drive the car on Kill Mode until the next version
Because you had “no way” to switch to low boost anymore? ![]()
I found a solution: edit “menu / Usernames” and save the map on your laptop, restart the V3 software and reload the map on your EMU.
Hello. I’m constantly tuning for drag cars. The part that makes me happy the most is “dome pressure control”. However, there is one feature I would like to add, if it is possible;
We want timer1 to be active after launch control. Normally, we would create a virtual output by doing this by adjusting the vehicle speed. However, we want the ign correction timer and boost timer to start after launch. This will give us an advantage in drag sport.
Best regards.
Do you think the software is in such state that if I get the car fully tuned on 3.025 there might be so big changes in future updates that will make the map invalid, required to retune?
Some time ago I asked for dark mode. I have a different request now. Can we have an option to set the background a custom clour? this way it would be much easyer to know in which map i am at the moment. Or at least, that i can colour the frame differently. and save it in the .emub3 as well. Like this:
Dark mode on top would still be much appreciated. ![]()
The problem is that darkmode for standrad widows controls doesn’t work properly.
Wiht the custom colors we will check what is possible
Is it possible to import (open) tables from Classic?
Copy / Paste between open EMU Classic and Black V3 would be nice as well for tables.
Copy/paste shoukd work from classic to v3.
Actually itbisbnot advised to load project from v2.
It’s not working for me. Also cannot open Classic exported tables in V3.
Sure project will not work, but tables… I’m doing cell by cell now… [Ignition/VE/Lambda for the moment]
To be exact, copy works from Classic and V3 and paste to Notepad works (just tried it), but paste in V3 does not work (it pastes “old” copy from V3, kind of ignoring the “last copy” done on the Classic).
EDIT: It seems I solved my issue with importing tables between Classic and Black V3. Changing the filename from *.emut to *emubt allows to import them to V3. But no idea why copy/paste does not work.
