Hi all! Sorry for dumb question-is subaru trigger 36-2-2-2 supported? in the trigger dropdown it states “NOT IMPLEMENTED”. Will i have to wait for new beta update for support?
I plan to provide updated firmware tommorow afternnon with working Subaru 36-2-2 trigger.
I will say that for my setup on initial tests,3.24 seems a lot better than 3.23. I know there is likely work going on in the back ground that doesn’t make it to the release notes but this build seems miles ahead for me. I didn’t make any significant changes to the map after upgrading and the drivability seems better, the Short term correction isn’t struggling like it was for me. I have some work to do in the VE table but I’ve never claimed it to be perfect.
In any case, initial impressions is very good. I’ll get some more testing and real KMS on it today to see if I can back up my initial impression.
Found 2 bugs!
Project saves only intermittently. I’m setting up my new map for the fourth time this week from scratch. I save after every change however opening *.EMUB3 file after restarting V3 client, map is blank again.
Switches-Mux Switch-options are grey’ed out when “Mux Switch Enabled” is checked.
Can you write step by step how you create a project that desnt save ?
With details please.
We know that there is such a problem but we cannot reproduce it.
According mux switch added to the bug list.
Is the mux switch issue on 3.024 version ?
It works ok on my computer.
Will update. Issue occurs after completion of simple startup map with all basic input/outputs/fuel/ign maps set. Just setting one input and saving works fine. Will attempt to recreate issue and catalog exact steps.
Functionality of MUX switch has not been tested, only interface. confirmed version 3.024.
When disabled, drop down and invert options are available for editing.
Dropdown and invert options turn grey when MUX enabled.
I can see now. It works backwards.
Do you create it offline or with the ECU connected.
All offline. It seems to be saving now, it is strange behavior. I would copy over values from V2 version and constantly hit save and overwrite v3 file, an hour later everything would be blank. Maybe user error on my part even though I have decent experience! Will update if it happens again. Sorry for inconvenience
I’m pretty sure that such problem occurs.
I’ve heard about this 3rd time. However we were unable to reproduce it.
Another small Thing:
Can you add a line on top that is dragable? Because the space on the right is a lot but i can’t make it smaller without cutting off letters of the parameters. (There are more of these windows. Not only DBW-Parameters)
Another small things:
- In Scope I can’t scroll from side to side like in LOG
- In LOG and Scope it would be cool to zoom in and out holding the Ctrl+Scroll like in brwoser and so on.
- In LOG If i have to zoom in or out: I just don’t get it. I use “A” and “Q” to zoom in and out and it just zooms somewhere. It would be nice to either zoom onto the “mouse courser line” or even better if I select an area then zoom into that.
→ Found it. You select an area and press “Z” = zoom extent
Thanks for you comments. Most of them are added to the bug tracker systems. Not all are doable, some are very interesting like the equation how the fuel is calculated in any point in the log (but very very hard to implement as all possible parameters needs to be logged).
the scope only gives me something when it syncs right? Can we get a “scope everything that appears even without sync” option? that way it would be easyer to see what signal is missing and so on.
and i didn’t need it so far, but probably handy in the future to change the length of the recorded scope to let’s say twice the length?
Hello, I miss the possibility to see the whole naming on the top of the main window.
It helps me to stay organized for exambple when Iam comparing projects.
Also custom naming in output/intput overview (blue and black bar in toolbar menu).
Could we please get an option to export (or copy text) “Assigned inputs/outputs”?
HTML export like PMU/ADU is nice but addition to that a .csv export would be nice too so you can make your own excel etc.
It is planned in next versions
i use an anolog input for my brake switch any way to add that into the switch options?
