V3 Studio 3.064 - new software version D
Could you say what operations did you perform that lead to crash ?
Is there a plan to modify the DIFF CONTROL strategy to provide more controller control options?
i have had 2 crashes now also, but it is not a crash in the way you get a just in time debugger where you can send the crash dump, it hangs the process and you have 2 use task manager to kill it and re launch.
No pattern yet, one time was in the fuel map, the other time was in the analog input settings.
I have a general settings table outside the main image, what should I do with it?
Same here, a 5% chance the software will crash when you click. I’ve lost count of the number of “no responding”. (I only tested offline, I did not test online.)
Opening a saved tune file, sometimes happens during the loading phase, other times it will happen in the background if you switch away from the application, but typically happens within a few minutes. I’m not sure if it’s being caused by opening files that have been saved in the 3.063 software.
I hade the same thing
I was uploading log and base map to investigate it and it crashed, another time i was changing different base map and log and crash again. Also when minimized sw window and later want to bring it back up it does not work anymore icon is on taskbar i press on it and nothing happens. Expected multiple times frozen screen with “Not Responding“ message. I am back to 3.063 and waiting for next update and waiting for boost target correction table by rotary switch input to be added too. :victory_hand:
Working on hang on issue
Is there a chance short pulse adder could be implemented? Idling on large injectors has always been an issue for us on these ECUs.
What is your resolution and Scale settings (Display settings/ Scale and layout) ?
There is a new build for V3 studio with fixed stability issue and improved connection time and desktop refreshing.
V3 studio 3.064d
Please let me know if it works for you!
where i can select the Analog Inputs for DBW ?
didnt finde the section.
In the classic it has dsg setting available does it mean it will be able to run it ?
When opening a saved log, the time is displayed incorrectly (set to System Time). When I disable this in the config, it shows the log time correctly, so seems to be an error only when displaying the system time.
OS: Windows 11
Software: v3.064 C (I think)
20260401_0808_00.emublog3 (2.8 MB)
@Jadzwin_ECUMASTER I will test the new E Dash app very soon. I just ordered the EDL-1 to replace my BT CAN module who was working with EMU Dash 3.
Was looking at the BT switch option and i realized it is missing in the NLS strategy, are you able to add it for the next release?
Sensors / TPS
Sensors / PPS
No, it is still beta for Classic. However there are some settings like engine torque that can be used for user CAN and for example Lamik TCU.
Will be added in next build.So far you can assing BT swtich to user switch
My laptop’s graphics resolution is 1366x768, with the new version 3.064d, even when changing the resolution, the problem is still there.
