V3 Studio 3.064 - new software version D
Hey guys is it safe to load firmware on classic
What do you mean? The whole ecu is buikd around one PID algortihm and it is very unlikely thtlat jt works incorrect.
Dear @Jadzwin_ECUMASTER
When we can expect similar functionality for EMU Pro ??
I spotted weird behavior on idle PID, enclosing log, it still reducing even its under target.
Also, i feel the armed+inactive state duty make idle control worse, as there is no look up for coolant temperature, so only where it can help is warm state maybe.
20260423_1622_V3idlePIDproblem.emublog3 (619.9 KB)
Hello! Ive got a gm LA1 (3.4L v6) in my fiero and I’m just getting to trying to tune it. Ive got drivability in the v3 software down and it does great to 3-3500rpm before it loses sync and cuts out. it uses the gm 7x (6+1) crank trigger where the 7th tooth is 10 degrees after tooth 6. It does utilize a vr sensor and weirdly the vr sensor signal is much cleaner with a 4k7 pull up. Doesn’t matter which polarity it is wired. Ive also got a hall cam sensor which is a half moon trigger. Do need to note that I have the firing order set as 3-1-2-6-4-5 in order to get the trigger and sync correct when trying to use tooth 1 on the crank. Not sure what else is going an as before this beta it did idle worse than after the beta update so it does seem to have changed something.
I am unable to attach files I have just created my account. I can email them to who ever needs to see them though.
Upload it and share the link
I just created the account, It won’t let me share stuff. When I get back to my computer ill figure something out to link it
Upload to Dropbox and share a link
I have set up the fuel and ignition tables switching with VTEC activation. The tables switch correctly, but in the logs, the tables set parameter constantly shows a value of 1. Shouldn’t it change to 2 when the tables are switched with vtec? In version V2, when tables switching was enabled via VTEC, this parameter definitely showed a value of 2.
Ever since I updated to version V3, the VE autotune function only works on the VE1 table, regardless of the settings in the parameters.
As the table switchng in v3 is much more flexible and there is no strict definition what is second tables set, you need to define the condtion that changes tables set (Log tables set function)
V3 software allows wasted spark configuration no problem, but using Studio V3 it lights up red with error message that output is already in use, why? How to go arround, or can we expect some fix ?
Kind regards
Even if you set the Mode as Wasted Spark you leave the firing order correct, no need to change it.
We do not change firring order mate, we try to tell the ecu what is correct ign output for each cillinder :wink:
oh sorry, got it wrong.
What was changed for the Lotus Elise wasted spark starting? I’m struggling with cold start on the old software at the moment. Wondering if this will help
It should help. If not please let me know, we will investigate the problem.
