V3 studio 3.071b
Actually it is fully enrcypted project.
I’m still thinking about the best way for partial project lock based on limited memory resources.
Hello, the issue is from 3.070 but I don’t see any fixes in changelog, that’s why post here:
Why the knock retard is not shows in Ignition Angle parameter?
It’s easy to check problems and other corrections if you watch ingtition angle and ignition from table, but it isn’t shown in actual ignition angle.
it’s special thing or bug?
screenshot and the log file are picked
to_ecm_developer_knock_retard.emublog3 (67.7 KB)
Huge update! Thanks all for the work in the graphic interface - looks amazing
If you are using 3.071 please upgrade windows client to 3.072. It fixes some issue with the uploading data to ECU using base map selector and partial import.
Hi Guys, something is not making sense. look below the VE is set for an AFR of 11.5 and 12.5 and ve is set on 106 for that range but look how rich it goes to 9 so there is no ajustment i can do there this is with no additional fuel just pump.
Would it be possible to make the ignition correction tables active on idle control? On v2 I use it in conjunction with raising the idle dc & reducing timing to create and anti stall feature and if possible a clutch down idle dc modifier
What is your PW ? It is hard to diagnose without the log file.
What are your overrun settings?
Sorry guy’s let me share the zip file have a few full runs done in the logs
06113838.BG3 (2.2 MB)
06114145.BG3 (4.2 MB)
Audi s3 8l r32 fuel redo upgrade 72.emub3 (68.9 KB)
06111250.zip (4.9 MB)
Morning guys, please help; I loaded the files and logs regarding the AFR and VE tables, but I cannot seem to identify the issue.
Hi Matt, i posted the log file
