Before i install version 3.068 shot term trim are not working.
Can understand this. So is Short trim working now or not? Log and map please..
And what is ur expectation now?
no is not workin before i install version 3.068,
LAUNCH TEST 3.1.emub3 (69.4 KB)
Share a log. In ur config nothing is abviously wrong.
You have “Always Active” set for Disable switch. Basically it will forever not activate. Set that to “None”
always active o none ha ve the same result dont work,
Im thinking to reistall soft wear again.
Should be working at that point. Post a log after that change
short term trim dont work.emublog3 (235.9 KB)
pid retard 60 2da a 13.5.emub3 (69.8 K
INSTALL VERSION 3.070 THE SAME PROBLEM
You still have always active selected…
