New software 3.054 is available!
So short story here: I kept updating now and then. at some point i got the Warning:
I ignored this until now and just skipped all the warning and errors and didn’t have any problems so far. (More errors appear when connecting via USB to Black) But now I’m really getting startet on my engine since all the mechanical problems should be solved soon so I wanted to do that properly.
So i now opened a fresh project in current software and wanted to use the compare Parameters function to get some of my parameters into the new project faster. I only can click on one parameter at the time and right click to “use file value…” would it be possible to:
  • sort by stuff: like inputs, outputs etc.
  • or put a search bar so that i can search for all inputs or outputs etc.
  • for me to click more than one value with control and/or shift to import more at once?
  • or double click to use that file value in the project? would be fast as well.
or something like that.
Thank you :slight_smile:
Edit: Just went through the list manually line by line. Took me like 2min actually. So i think this is not really important. :grin: Sorry for bothering.
When we can expect sw update for ecumaster black v3? At the moment(3.054a) when i double click on any table to open/close working only open if window is not opened at that moment, if window is opened and hided in background you should close/move rest windows to find it, a bit annoying and slows down work. :slight_smile: :victory_hand:
Here is a fixed software:
https://www.ecumaster.com/files/EMU_BLACK_V3/EMUBlackV3Setup_3_054b.exe
since I tryed new wersion 3_054b - Iam not able to see scatter plot in following setup.
X axe - RPM
Y axe - Rev limiter target CAN BUS (Using this chanetl because of sampling resolution)
Z axe - CLT
Please publish log I will check.
Hello, sorry for my delayed respond.
Here is it . . .
Série.emublog3 (189.3 KB)
Regarding PitLimiter
Am i wrong to expect it as a BIT field ?
In AIM it is a PitLimit Touque reduction % ?
/M
Edit - solved our VVT issue, however, lambda is very erratic, even after calibration, not sure there’s much we can do about this. We have checked the sensor using another reader and the sensor is fine. It doesn’t match even vaguely the readings of a standalone sensor. I’ve added the 5v feed to make sure I don’t get the wide open sensor failure, but can’t get any good readings at all.
My trigger seems to be having issues in V3, using the Rover 18-1-18-1 Crank settings. It seems to be ignoring most of the teeth on the wheel. When I downgrade the firmware 2.175, I get the correct patterns on the Cam and Crank. Same trigger settings between the two. Any suggestions?
Engine: QG18DE
ECU: EMU Black (USB-C)
V3 Map: alpha N 2.emub3 (65.1 KB)
V3 Scope: scope_2025816_1634 Rover 18-1-18-1 all teeth.emubscp3 (634 Bytes)
V2 Map (just thrown together to crank and get the scope reading): polo_qg18_v2.emub (146.1 KB)
V2 Scope (can’t upload the file):
Crank Wheel:
Thanks for the increase of the rev limiter!
I am updating to 3.054 and increasing the rev limiter a bit. I have not tested the new limiter at the track yet. I can increase the values in the rev limiter tables, but the Rev limiter target measurement variable still shows a maximum of 15000 RPM.
I think the new increased rev limit probably works and that its only the range of the measurement point that needs to be fixed?
The max value, redline and alarm value for the Rev limiter target can not be increased higher than 15000 RPM.
Is there any option to pop up table selected at parameters list? I mean, in V2 when i have already that table somewhere hidden under other tables or log in desktop window, when i select it again in parameters, it pops up as its active table. In V3 does not, so i must search and dig for it.
Is there a bug in the MAP readings for V3? This is on a 2zz Lotus. We have two issues currently, one where despite setting it 3 times it’s coming back with readings at 200kpa+, and another where it doesn’t seem to be giving us the right temp readings. It doesn’t seem to be reading the air temp on startup correctly.
Send the log with the erratic readigs.
In V3 now when the table is on the desktop and you click on the tree view the table hides. Press again and it shows on the desktop.
It is only log issue. In the XML file the max RPM is defined as 15000.
It will be adjusted in next buld
Please publish your MAP sensor settings.
It is very unlikely that there is a MAP sensor readings bug, as it is a common feature used by many, many users.
In V3 this signal is converted to 12 tooth (multitooth).
The PIT limiter active is a flag:
There is also a channel Pit limiter torque reduction, and it is possible that this channel is used by AIM.
I use your log and it works fine.
Are you sure you havent sleceted very small amount of log ?
The scatter plot display selection (if part of the log is selected) or the whole log where there is no selection.
That make more sense..
I will test that, thanks.
/M
