New software 3.056 available!
Thanks Jadzwin - Haltech V2. I’ll upload this one today :call_me_hand:
Where’s the option for this? Had a look in triggers, and starting menus but couldn’t find it
The icon display is now perfect with the revised version. Thank you.
I apologize for going into one more detail. The ‘>’ and ‘∨’ marks on the far left of the menu tabs (marks that indicate a tree structure)
are almost the same color as the background in dark mode, making them difficult to see.
I think a lighter color would make them perfect.
I am just starting a r32 bub from v2 to v3 .. the trigger settings have been adopted , the motor only starts and runs if I set the secondary trigger to off , what can I change ? I have attached two scopes where the setting is off and one
And since it's a DSG, are the settings correct for the CAN? I don't have the option to read the CAN stream. Can I do something with VCDs?
scope_2025916_1614 not use.emubscp3 (539 Bytes)
scope_2025916_1613 n+1.emubscp3 (566 Bytes)
Dark mode?
Awesome. :grin:
My engine starts really well with it activated now. Great work @Jadzwin_ECUMASTER :+1:t2:
black mode is too good! thank you.
may i ask what are the BT switches? also what is the RX switch
BT switches are for upcoming android application.
Rx switch is from the emu Rx input
If you dont use EDL you can use Rx pin as a switch.
More details in help
in the new firmware if you open up a boost gauge while the boost log is open it will cause the software to crash. also is there a way to resize the configuration window? i have to switch my laptop into tablet mode in order to access the top two parameters and then switch back to laptop mode to close the configuration window.
The issue with the configuration window need to be resolved. It is on the list.
Thank you reporting the crash, I can reproduce it.
It just keep getting better.
Thank you.
Where in the help can I find the details about RX switch?
CAN streams fixed - thankyou!!! Startup dramatically improved for my 1JZ also.
Predeffined logging chanells are doubled
It was fixed before but I see this appears again. I will check
i noticed the beep sound on making permanent changes doesnt sounds allways and another bug maybe will be if i opened the window with ecu connected it allways asking for using changes from pc or emu…that wasnt there before….
Am also curious how the new fw handles wasted spark settings? How it will work if i let settings like on sequential injection? Or i have to set injection on ignition event? thats all? or i have to set inj twice too?
What can cause injection pw spikes like this? It seems as logging bug because lambda is stable…
Publish the log fike
Software freezes on first lunch start,
On windows 7 ultimate.
